  3. Getting Started
How to Adjust the Mudita Oasis Seat Height and Firmness
One of the defining features of the Mudita Oasis meditation set is its highly adaptable, tool-free design. Equipped with a unique 3-insert system, the cushion allows you to fine-tune both seat height and firmness in seconds, ensuring your posture remains effortlessly upright and comfortable throughout your practice.
The cushion relies on three distinct layers that work together to create the perfect seating surface. Depending on your body's flexibility and comfort needs, you can stack or remove these components:
  • Buckwheat Core Insert: this is the primary filling of the seat and should always be used as the base layer inside the cushion.
  • Coconut-Fiber Stabilizer Insert: positioned directly on top of the core insert, this layer anchors your pelvic tilt and supports a naturally straight spine. (Note: in the Memory Foam version, this insert also includes an integrated layer of memory foam for extra cushioning.)
  • Extra Buckwheat Insert: an optional top layer used to gain maximum height and introduce a softer, more adaptive feel to the seat.
Height and Firmness Configurations
By combining these inserts, you can customize the cushion into three distinct setups to match your daily physical requirements:
ConfigurationApproximate HeightThe Seating Feel
Buckwheat Core Only20–40 mm (0.8–1.6 in)Very low profile; minimal elevation
Core + Coconut Stabilizer60–100 mm (2.4–3.9 in)Firm, highly stable, and traditionally grounded
All 3 Inserts InstalledUp to 150 mm (5.9 in)Full height; maximum ergonomic support
Adjusting your setup takes only a moment and requires no extra tools:
  1. Locate the YKK zipper on the cushion and unzip the hemp-cotton cover.
  2. Add or remove the modular inserts to achieve your desired height and firmness level.
  3. Smooth down the fabric and zip the cover completely shut.
