Is Mudita Oasis suitable for beginners?
Short answerMudita Oasis is designed to be accessible to all experience levels - from first-timers to experienced daily practitioners.
How it supports beginners
  • Adjustable 3-insert seat: Lets you start at a specific height and firmness that matches your current flexibility, making it easier to sit comfortably.
  • Flip-height bolsters: Allow you to easily adjust leg support, which significantly reduces joint strain during your early practice.
Mudita Oasis Memory Foam is especially well suited to beginners. The added memory foam layer provides extra cushioning at the knees and hips, offering a softer and more forgiving experience as your body adapts to the posture.
