Mudita Harmony 2.6.1
Short answerLets Harmony turn on with 5% battery, speeds up updates and fixes two bugs, including a freeze after fast volume changes.
This release lets the Harmony power on with a minimum battery level of 5%, speeds up the update process and fixes two bugs.
Click here to learn how to update your Mudita Harmony using our desktop app, Mudita Center.
You can download the latest version of Mudita Center here.
Below is the list of changes implemented in our latest release of the Mudita Harmony's system.
New features
  • Implemented a new feature that allows the Harmony to be powered on with a minimum battery level of 5%.
Enhancements
  • Updated FSL drivers from NXP for improved system performance.
  • Accelerated the speed of the update process, ensuring quicker and more efficient software upgrades.
Bug fixes
  • Resolved errors associated with BIWIN eMMC memory, enhancing storage reliability.
  • Addressed an issue where the user interface would freeze after making rapid adjustments to the volume, ensuring smoother operation and user interaction.
