Mudita Harmony 2.8.0
Short answerAdds custom alarm sounds, an update instructions screen and volume control for the focus timer. Fixes seven bugs.
This update adds support for custom alarm sounds, an update instructions screen and volume control in the focus timer. It also resolves seven bugs.
Click here to learn how to update your Mudita Harmony using our desktop app, Mudita Center.
You can download the latest version of Mudita Center here.
In this update, we have introduced several new features and improvements to enhance your experience. Notably, we added support for custom alarm sounds. There's also an update instructions screen available now at the end of the onboarding process and in the Settings section. Additionally, users can now customize the volume level in the focus timer application. We've also resolved seven bugs in this release.
New features
  • Custom Alarm Sounds: Users can now add their own alarm sounds through the "Manage Sounds" tab in Mudita Center.
  • Update Instructions Screen: Now available at the end of the onboarding process and in the Settings section.
  • Focus Timer Volume Control: Users can now set the volume level in the focus timer application for a more personalized experience.
Improvements
  • Extended Charger Support: We have expanded the range of supported chargers.
  • Enhanced Device Stability: Improved stability when using low-quality USB cables.
  • Settings Menu Order: The options in the Settings menu have been reorganized for better navigation.
  • Progress Bar Screen Refresh Rate: The refresh rate of the progress bar screen has been optimized.
This release aims to provide a more user-friendly and customizable experience.
