Mudita Harmony 2.5.0
Short answerAdds low battery alerts below 15% and longer battery life, and fixes alarms ringing after being turned off during snooze.
This update focuses on improved battery management, with low battery notifications and longer battery life, plus some bug fixes.
Click here to learn how to update your Mudita Harmony using our desktop app, Mudita Center.
You can download the latest version of Mudita Center here.
We're excited to announce the latest update for Mudita Harmony, version 2.5.0.
This update focuses on enhancing your experience through improved battery management and fixing some known issues to ensure smoother operation. Here's what's new and improved:
What's new
  • Low Battery Notifications: You'll now receive alerts on the home screen and when attempting to open an application if your device's battery falls below 15%. This ensures you're always aware when it's time to recharge.
  • Battery Life Improvements: We've introduced low power CPU modes that activate when your device is not in use, significantly extending the battery life. Additionally, we've optimized the system to reduce power consumption further by adjusting how the memory operates when you're not using your device.
  • Date Settings Update: The onboarding process has been updated to reflect the current year, making setting up your device even easier.
Bug fixes
  • Alarm Behavior: We've corrected an issue where alarms would still go off even if they were deactivated during the snooze period.
  • Relaxation App Notifications: We've resolved a bug where you might receive a notification about file deletion in the Relaxation app, even when no file was actually removed.
We're continually working to improve your experience with Mudita Harmony and appreciate your feedback. Enjoy the enhancements, and look forward to more updates in the future!
