Short answerAdds Colors of Noise to Relaxation, a brightness fade-in for the alarm and the MM/DD date format, and fixes an E Ink crash.
This release adds Colors of Noise to the Relaxation app, a brightness fade-in for the alarm and the MM/DD date format.
Click here to learn how to update your Mudita Harmony using our desktop app, Mudita Center.
You can download the latest version of Mudita Center here.
We're excited to announce the newest release of Mudita Harmony v2.3.0, which brings a variety of enhancements and fixes to improve your experience.
Here's what's new:
Added
- Relaxation Sounds Expansion: We've enriched the Relaxation application with a range of "Colors of Noise", including White, Brown, Pink, Grey, and Ultra Noise.
- Brightness Fade-In for Alarm: Wake up gently with our new brightness fade-in feature, making your mornings smoother.
- Enhanced Date Format Options: You can now set dates in the MM/DD format, providing more flexibility in how you view time.
- Sound Categories in Relaxation: Discover categorized sounds for a more tailored relaxation experience.
Bug fixes
- E Ink Crash Resolved: The issue causing the E Ink display to crash during refreshes has been fixed.
- Background Playback Bug: We've resolved the problem where songs occasionally played in the background after finishing.
Changes and improvements
- Optimized Music File Loading: The Relaxation application now loads music files more efficiently.
- Updated Time Setting Flow: We've made the time setting process more intuitive.
- Improved Factory Reset Translations (Polish): The Polish translations for factory reset instructions have been clarified to avoid confusion.
Thank you for choosing Mudita Harmony.
Enjoy the improved functionality and smoother experience with this latest update!
