Mudita Harmony 2.2.1
Short answerFixes 8 issues, including the meditation timer, the snooze icon staying on and uploads of music files with images in their metadata.
Click here to learn how to update your Mudita Harmony using our desktop app, Mudita Center.
You can download the latest version of Mudita Center here.
In this release, we focused on fixing bugs. We resolved 8 issues to ensure smoother operation of the Harmony.
Fixed
  • Resolved an issue with the meditation countdown timer when a deep press is performed.
  • Smoothed out the screen refresh process when turning on the device.
  • Fixed the snooze icon not disappearing when the alarm is deactivated.
  • Solved the problem of incorrect messages shown after changing the alarm settings in some scenarios.
  • Removed the possibility of an OS crash when checking the update package size.
  • Fixed errors that occurred when trying to upload music files with graphics in the metadata through Mudita Center.
Added
  • Files not fully transferred via Mudita Center will be now removed if the USB cable is unplugged.
Changed/Improved
  • Improved the display time of the "turn off" window.
  • Hardware faults during device startup now result in shutdown and a more user-friendly message.
  • Changed the appearance of the display when the battery is discharged.
