Mudita Harmony 2.2.0
Short answerImproves system stability and crash handling, and records manual resets in the logs.
This update improves the overall stability of the Harmony's system and the handling of crashes.
Click here to learn how to update your Mudita Harmony using our desktop app, Mudita Center.
You can download the latest version of Mudita Center here.
Here is the list of changes implemented in this update:
General
  • Improved the overall stability of the Harmony's system.
  • Improved hard fault handling during crashes.
  • Performing a manual reset will now be noted in data logs.
