  3. All You Need to Know
Importing, Exporting, and Deleting the Mudita Pure Contacts with Mudita Center
The Mudita Pure has a contact list (phone book) where you can store phone numbers. It is possible to separate contacts by favorites. The most convenient way to manage your contacts is through our desktop application Mudita Center.
Importing Contacts into the Mudita Pure (using a VCF file):
  1. Open Mudita Center, connect your Pure to the computer and wait for the phone to sync with the application.
  2. Go to the “Contacts” section under “YOUR PURE”.
  3. Click on “Import”. You will see several options to import contacts.
  4. Click “Import from VCF file” and choose a file from your computer to import. Make sure that you have exported your contacts into a VCF file.
  5. Once the file is chosen to import, you will be able to see the list of the contacts (you can choose contacts to import).
  6. Click the confirmation button to start the import process.
  7. After the process is finished successfully, you will be able to view the contacts in Mudita Center and on your Mudita Pure.
Importing Contacts into the Mudita Pure from Google Contacts:
  4. Select the “Continue with Google” method. It will bring you to the next modal with authorization (you will need to log in to your Google account).
  5. Now you can choose which contacts you want to import and follow the instructions.
  6. After the process is finished successfully you will be able to view the contacts in Mudita Center and on your Mudita Pure.
Importing Contacts into the Mudita Pure from iCloud:
There is no option to directly sync Pure contacts with iCloud. In order to import your iCloud contacts into the Pure, please export the contacts into a VCF file. Once you have that ready, please refer to "Importing Contacts into the Mudita Pure (using a VCF file)" above.
Exporting Contacts from the Pure into a VCF File:
  3. Select the contacts you want to export.
  4. Click on “Export” in the upper section of the window.
  5. Choose the file name and location for your exported contact list.
  6. Once finished, you see a confirmation message that your contacts are exported to the file.
Deleting Contacts from the Pure:
  3. Select the contacts you want to delete by clicking the check boxes next to them. It is possible to select some or all contacts.
  4. Click on “Delete” in the upper section of the window.
  5. All of the selected contacts will be deleted from your Pure.
