  3. Connectivity
How To Connect Devices Using Bluetooth to Mudita Kompakt
Before starting, ensure the device you want to connect to has Bluetooth turned on and is discoverable.
To connect a device:
  2. Tap Settings icon
  3. Tap Connected Devices
  4. Tap Pair new device
  5. If you see a notification “Bluetooth is on”, tap x to dismiss it
  6. Select the device you want to pair with from the list
  7. Tap Pair
