  3. File Transfer
How to Transfer E-books to Kompakt?
You can easily transfer e-books to your Kompakt using Mudita Center. Follow the steps below to upload your e-book files
  1. Open Mudita Center and connect your Kompakt to your computer.
  2. Under Your Kompakt, click Manage Files.
  3. Select the E-books tab.
  4. Click Add file.
  5. Browse your computer and select the e-book files you want to upload.
  6. Confirm the transfer to copy the selected e-books to your Kompakt.
Important: If a file format is not supported by Kompakt, you won't be able to select or upload it.
