  3. Connectivity
How To Use Offline+ and Airplane Mode on Mudita Kompakt
Airplane mode disables the antenna and Wi-Fi, but still allows you to turn on Bluetooth.
To turn airplane mode on or off:
  2. Tap Airplane icon
Offline+ is more than Airplane mode as it disables the antenna, microphones, camera, Wi-Fi and Bluetooth.
To use offline+:
  1. Slide the Offline+ switch* to the down position
To enable the full phone function:
  1. Slide the Offline+ switch to the up position
*The Offline+ switch is located on the left side of Kompakt
