  3. Connectivity
How To Use Wi-Fi and Create a Hotspot on Mudita Kompakt
How to connect to Wi-Fi
  2. Tap Settings icon
  3. Tap Network and Internet
  4. Tap Wi-Fi
  5. Select the Wi-Fi network you want to join
  6. Enter the Wi-Fi network password
  7. Tap Connect
How to share Wi-Fi password
  4. Tap Wi-Fi
  5. Select the Wi-Fi network you are connected to
  6. Tap Share
  7. Touch the power button to scan your fingerprint or tap USE PIN > Enter PIN
  8. Either scan the QR code with the other device, or copy the Wi-Fi passcode manually
How to create a hotspot
Hotspots allow other devices to use Kompakt’s Wi-Fi or data when they are tethered.
To create a hotspot:
  4. Tap Hotspot and Tethering
  5. Tap Wi-Fi Hotspot
  6. You can edit the name, password* and security settings for the hotspot
  7. To turn on the hotspot Tap the Toggle Switch near the top of the screen
*The password must be 8 or more characters long
You can also turn the hotspot on and off from the Control Center:
  2. Tap Hotspot icon which is above the Airplane icon
