In order to activate and deactivate the alarm on your Mudita Harmony, please deep-press the main knob on top of the device.
Orange Strip Marks the Position
Deep-pressing the main knob will cause it to switch between positions:
  • If the orange strip is visible, that means the alarm is active and will ring at the specified time.
  • If the orange strip is not visible, that means the alarm is turned off and will not ring.
When you change the position of the knob, the clock will display a message on its screen, informing that the alarm is either deactivated or that it will ring at the specified time.
When the alarm is active, the Harmony will also display a bell icon with the time of the alarm on the home screen.
Click here to find out how to set and customize your alarm.
