Below is a guide on how to access the alarm settings on a Mudita Harmony, as well as what all the settings include and how to change them.
Click here if you want to know how to turn the alarm on and off.
Access the Alarm Settings Menu
When the clock is on its home screen, light-click the main knob on top of the device to enter the menu.
Twist the main knob right to scroll down to "Settings", then light-click it to enter this part of the menu.
In the "Settings" menu, scroll down to "Alarm" and light-click the main knob to select.
This will take you to the part of the menu, where you can change the pre-wake up, main alarm, and snooze settings. Select the one that you'd like to change by light-clicking the main knob when it's selected on the screen.
Pre-Wake Up
In the first step, you will be able to set how long before the main alarm should your Hamony sound the pre-wake up chime. The chime can ring 5, 10 or 15 minutes before the alarm, or it can be turned off entirely. Twist the main knob left and right to navigate between these options, then light-click to select the one you like.
If you activate the pre-wake up chime, you will be able to select its tone in the next step. There are 4 different sounds to choose from. Twist the main knob left and right to listen to them, then light-click it to select the one you like.
The next step is to choose the pre-wake up chime volume from a scale of 1 to 10. Twist the main knob left and right to hear the volume levels, then light-click it to select the one you like.
Finally, you will be able to choose if you'd like the clock's screen to light up during the pre-wake up phase. Like with the chime, the light can activate 5, 10 or 15 minutes before the alarm, or it can be turned off entirely. Twist the main knob left and right to navigate between these options, then light-click to select the one you like. Next, choose the brightness in the same way.
Main Alarm
In the first step, you will be able to choose the sound of the main alarm. The Mudita Harmony has 17 alarm sounds to choose from. Twist the main knob left and right to listen to them, then light-click it to select the one you like.
After choosing the alarm tone, the next step is to set its volume from a scale of 1 to 10. Twist the main knob left and right to hear the volume levels, then light-click it to select the one you like.
Finally, you'll be able to select if you'd like your Harmony's screen to light up as the alarm rings and how bright it should be. Choose if the light should be on by twisting the main knob left and right, then light-click it to confirm your choice. Next, choose the brightness in the same way.
Snooze
First, you will be asked to choose if you'd like the snooze feature to be on or off. Twist the main knob left and right to navigate these options, then light-click it to confirm your choice.
If you turn snooze on, you will then be able to select how long the snooze time should be, that is how long the clock should wait before it rings the main alarm again after snooze is triggered. This can be between 1 and 30 minutes. Twist the main knob left and right to reduce or increase the time, then light-click it to confirm your choice.
Next, you wil be able to select the snooze chime interval. The snooze chime is a recurring signal that the Harmony sounds when in the snooze phase. It can be set to between 1 and 5 minutes or it can be turned off. Twist the main knob left and right to navigate between these options, then light-click it to confirm your choice.
If you choose to turn the snooze chime on, the next step is to select its sound from the 4 available options. Twist the main knob left and right to navigate between them, then light-click it to confirm your choice.
Once you choose the chime sound, the final step is to set its volume from a scale of 1 to 10. Twist the main knob left and right to hear the volume levels, then light-click it to select the one you like.
