Mudita OS 1.1.5
Print
Modified on: Tue, 7 Mar, 2023 at 5:54 PM
In this release, we worked on technical improvements. Furthermore we have solved 13 bugs.
Changed:
Bluetooth:
The default device name has been changed.
Keyboard:
Keyboard backlight settings changed.
UI/UX:
Mudita logo display on turned off phone disabled.
Fixed:
UI/UX:
Fixed design of icons in Calls app.
Battery:
Fixed issue with incorrect display of battery status after device restart.
Screen:
Fixed issue with the screen backlight turning off too quickly.
Alarm:
Fixed problem with inability to set alarm snooze.
Fixed problem with data reset when custom alarm settings are entered.
Fixed problem with receiving messages when phone is offline mode.
Fixed errors in text translations.
General:
Fixed problem with the incorrect message when trying to enter a PIN code.
Calls:
Improved the sound quality of headphones during a phone call over HSP.
Bluetooth:
Fixed problem with music playing after disconnecting and reconnecting BT device.
Contacts:
Fixed problem with contacts disappearing after editing them.
Did you find it helpful?
Yes
No
Send feedback Sorry we couldn't be helpful. Help us improve this article with your feedback.
