  2. Products
  3. How To Use Mudita Kompakt
How To Manage Sounds and Volume Levels
How to change the volume level
There are 2 ways to change the main volume level on Kompakt but you can also change the levels for certain functions like the alarm or ringtone too.
To set the main volume though the Control Center:
  1. Press the Control Center button
  2. Swipe the sound volume bar below the Bell icon up or down
To set the main volume using the volume buttons:
  1. Press or hold down the volume up button to raise volume
  2. Press or hold down the volume down button to lower volume
To change the volume for certain functions:
  2. Tap Settings icon
  3. Tap Sound
  4. Use the sliders to set the level you want
How to put Kompakt in silent mode
There are 2 main ways to put Kompakt into silent mode.
To set silent mode though the Control Center:
  2. Tap the Bell icon or swipe the sound volume bar all the way down
To set silent mode using the volume button:
  1. Hold down the volume down button until the sound volume bar is all the way down
How to turn certain sounds on or off
  3. Tap Sound
  4. Tap Advance
  5. Use the toggle to turn on or off sounds for:
    1. Dial pad presses
    2. Screen locking
    3. Charging (includes vibration)
    4. Touch sounds (button presses etc.)
