Mudita Harmony 1.5.0
Short answerAdds scrolling between settings, a set order and updated sounds for alarms, and fixes 14 bugs, including battery status errors.
In this release we have added additional navigation functions in the settings section. We have also updated the settings for alarm sounds.
Moreover we fixed 14 bugs in our application.
Added
Settings
  • Ability to scroll between Harmony settings
  • The order of alarm sounds has been defined
Changed/Improved
Alarm
  • The default alarm volume has been changed
  • Updated alarm sounds
General
  • The welcome screen has been updated
Fixed
Pre-wake up
  • Fixed problem with pre wake-up light
General
  • Fixed problems with device turning on despite high battery level
Battery
  • Fixed problems with incorrect display of battery charge status
  • Fixed issue with the device turning on when the battery is critical, even if a charger is plugged
Meditation
  • Fixed problem with the occurrence of duplicate texts
Settings
  • Fixed problem with alarm sounds appearing after changing device language
  • Fixed problem with opening the Menu section when confirming the alarm setting
  • Fixed problem with resetting remaining settings after changing language settings
Translations
  • Fixed gaps in translations
Alarm
  • Fixed a problem with setting a new alarm sound
