  3. Kompakt and Mudita Center
How To Manage Contacts With Mudita Center
How to import contacts from CSV file or vCard
Before you start, you need to create a CSV using outlook, create a vCard using Google Account or create a vCard (VCF file) using iCloud.
  1. Open Mudita Center and connect your device
  2. Look under Your Kompakt > Click Contacts
  3. Click Import contacts
  4. Click Upload CSV or vCard
  5. Select the CSV or Vcard file from your computer
  6. Select the individual contacts to import or select All contacts
  7. Click Import selected contacts to transfer contacts to phone*
*Important - do not disconnect your phone while the import is in progress
How to import contacts from Google
  4. Click Google
  5. Log in to Google
How to import contacts from Outlook
  4. Click Outlook
  5. Log in to Outlook
How to create a vCard (VCF file) using iCloud
  1. On your computer, sign into your iCloud account using your Apple ID
  2. Click Contacts
  3. Select the contacts to export either by using ctrl + click or shift + click*
  4. Click the Export Icon
  5. Click Export vCard
  6. The vCard (VCF file) should appear in your downloads folder
*To quickly select all contacts, click the 3 dots in a circle icon > click Select All
How to create a CSV or vCard using Google Account
  1. On your computer, sign into your Gmail account using your Google ID
  2. Click the Grid icon to show the apps list
  3. Click Contacts
  4. Select the contacts to export
  5. Click the 3 dots icon
  6. Click Export
  7. Select how you would like to export the contacts, either CSV or vCard
  8. Click Export
  9. The CSV or vCard should appear in your downloads folder
*To quickly select all contacts, click the down arrow icon > click All
How to create a CSV file using Outlook
  1. On your computer, sign into your Outlook account using your Microsoft ID
  2. Click the People icon
  3. Click the Manage contacts
  4. Click Export
  5. Click Export
  6. The CSV should appear in your downloads folder
How to delete contacts using Mudita Center
  3. Hover the mouse pointer over contact you want to delete
  4. Click the Checkbox to select the contact*
  5. Select any other contacts you want to delete
  6. Click Delete
  7. Click Delete
*To select all, click the minus icon near the top of the screen
