  3. Calling & Messaging
How To Make Calls and Manage Emergency Number on Mudita Kompakt
How to make a call on Kompakt
To call a contact:
  1. Tap Phone
  2. Tap Contacts
  3. Select the contact you want to call
  4. Tap Call
To call a new number:
  1. Tap Phone
  2. Tap Dial
  3. Enter the number you want to call
  4. Tap the Call icon
How to block a number from an incoming call
When you receive a call from the number you want to block:
  1. Tap the Block icon
  2. Tap Block number
How to change the emergency call number
Warning! Your emergency call may not be answered if you change the default number!
The default emergency number is for the emergency services in your state or country.
To change the emergency number:
  2. Tap Settings icon
  3. Tap Safety and Emergency
  4. Tap Emergency Call
  5. Tap Call in case of Emergency
  6. Tap the existing number
  7. Enter the new number
  8. Tap Save
