Short answerOpen SMS, tap the Pencil icon for a contact or the Plus icon for a new number, write your message and tap Send. The steps for MMS are below.
Send SMS Message to a contact
- Tap SMS
- Tap the Pencil icon
- Select the contact you want to message
- Enter your message*
- Tap the Send icon
*If the keyboard does not appear, tap the blinking cursor
Send SMS Message to a new number
- Tap SMS
- Tap the Plus icon
- Enter the phone number
- Tap send to: xxxxxxxxxxx
- Tap the Send icon
Send MMS Message to a contact
- Tap SMS
- Tap the Plus icon
- Tap the Image icon
- Select the image you want to send
- Tap Send
Send MMS Message to a new number
- Tap SMS
- Tap the Plus icon
- Tap Send
How to delete conversations
- Tap SMS
- Select the conversations you want to delete
- Tap Delete
- Tap Delete
