When your Bell is a new unit or when it runs out of battery power, we recommend charging the device for at least 2-3 hours before using it. Charging from 5% to 100% should take about 5 hours.
Long-Lasting Battery
The Bell can last for up to 3 months of moderate use on a single charge. This can be considerably shortened by frequent use of the backlight or letting the alarm play long and on high volume.
Charging and Activating the Mudita Bell
Please plug the device into a USB charger or a computer’s USB port using the included USB-C cable or another similar cord. The clock should sound a signal when it's plugged into a compatible charger. It will also activate if it was previously turned off (if it's new).
If your Bell still does not react despite it being plugged into a charger, please try to perform a factory reset by pressing both top side buttons (settings and light) at the same time and holding them down for about 5-10 seconds. Release the buttons when you hear a ring signal and the backlight goes off.
If the reset doesn’t help to activate your device, the Bell may need more time to charge or it may require a different charger.
To charge correctly, the Bell needs a 5V USB power supply (our power adapters added to orders should work just fine). 5V is the standard voltage for USB ports, however some fast phone chargers have variable voltage and also support higher voltages like 9V, 12V or 20V.
Chargers with variable voltage may also work, but only when the Bell's battery isn’t already empty. That’s why your alarm clock might not charge with the power adapter that you’re using, even if it works well with other devices or if it previously charged your Bell.
If none of the USB chargers available to you seem to work, we recommend charging the Bell using a computer’s USB port, which should always have a 5V output.
Battery Level Status
To check the battery level, light-click the main button and hold it for about 2 seconds. The battery level will be indicated by distinct light and sound combinations:
95-100% of battery level:
The device will light up and sound 3 times. This means the Bell is fully charged and doesn't need to be charged.50-95% of battery level:
The device will light up and sound 2 times. This means there is still enough power and the Bell doesn't need to be charged.5-50% of battery level:
The device will light up and sound 1 time. This means the Bell still works and has some power, but will require charging soon. It's a good idea to charge it at this stage to keep it working.0-5% of battery level:
The device will flash the backlight 3 times and sound its low battery signal. This means the battery is empty or close to empty and the Bell should be charged immediately.
Low Battery Warning
When the battery level drops below 5%, the Bell will activate its low level battery warning. Any interaction with the clock will then cause its backlight to flash and the low battery signal to sound. In this mode, the clock's features are limited to time indication and the alarm. The clock then needs to be charged to restore its full functionality. Leaving it in this state will cause the battery to discharge completely.
Clock Still Not Responding?
