In this release we have added additional navigation functions in the settings section. We have also updated the settings for alarm sounds. Moreover we fixed 14 bugs in our application.
Added:
Settings:
- Ability to scroll between Harmony settings
- The order of alarm sounds has been defined
Changed/Improved:
Alarm:
- The default alarm volume has been changed
- Updated alarm sounds
General:
- The welcome screen has been updated
Fixed:
Pre wake-up:
- Fixed problem with pre wake-up light
General:
- Fixed problems with device turning on despite high battery level
Battery:
- Fixed problems with incorrect display of battery charge status
- Fixed issue with the device turning on when the battery is critical, even if a charger is plugged
Meditation:
- Fixed problem with the occurrence of duplicate texts
Settings:
- Fixed problem with alarm sounds appearing after changing device language
- Fixed problem with opening the Menu section when confirming the alarm setting
- Fixed problem with resetting remaining settings after changing language settings
Translations:
- Fixed gaps in translations
Alarm:
- Fixed a problem with setting a new alarm sound
