  3. Tips and Solutions
Mudita Harmony / Mudita Harmony 2 - Maintenance Tips
The Mudita Harmony and Mudita Harmony 2 alarm clocks don't require any special maintenance, but there are a few things to keep in mind to allow the clock to perform at its best.
Regularly Check for New System Updates
The Harmony and Harmony 2 alarm clocks receive system updates, which can be installed through our desktop app, Mudita Center. We recommend checking regularly if new updates are available. Keeping the clock's software up to date will allow it to be as stable and efficient as possible. It will also give you access to all the current improvements and features, offering the best possible user experience.
Click here to learn how to update the system on a Mudita Harmony or Harmony 2.
Keep the Battery Charged
To make sure that the Harmony will work correctly and ring the alarm when the time comes, it's important to keep the clock's battery at a sufficient state of charge. If the clock's system is updated to the latest version, the Harmony can last for 3-4 weeks of moderate use on each full charge. To easily keep track of how much power is left, we recommend selecting a clock face (in the settings), which shows the battery percentage on the main display.
Click here for more information about charging the Mudita Harmony and Harmony 2.
Avoid Excessive Moisture and Harsh Chemicals
Like with most electronic devices, it's best to keep the Mudita Harmony or Harmony 2 away from moisture to avoid damaging the clock. To clean it, we recommend using a clean, dry cloth and not use any harsh detergents that could stain the plastic.
