Can I Run Mudita OS on a Different Device than Mudita Pure?
Modified on: Thu, 17 Sep, 2026 at 1:12 PM
Mudita OS is our proprietary system developed specifically for the Mudita Pure and only supports the Pure.
Mudita OS on Other E-Ink Devices?
While it may be possible to run Mudita OS on a different e-ink device, that would require a lot of adjustments to the code. It isn't possible to install our system as it is on any other device but the Mudita Pure.
Should a user try to implement such changes to adapt Mudita OS to another device, all changes done to the software need to be released and documented under the GPL v3 license.
