  3. Mudita Radiant Automatic FAQ
How Should I Care For And Clean My Mudita Radiant Automatic?
Regularly wipe the case and the bracelet or strap with a soft, dry microfiber cloth to remove fingerprints, dust, and moisture.
Avoid any direct contact with chemicals such as perfumes, lotions, or detergents, as they can damage the finish of the case and the material of the strap over time.
