  3. Organization
How To Create and Delete Notes on Mudita Kompakt
How to create notes
  1. Tap Apps
  2. Tap Notes
  3. Tap the Plus icon*
  4. Write a title for your note (max. 54 characters)
  5. Tap Enter on the keyboard
  6. Write more detail for your note
  7. Tap Done
*If it is your first note, tap Create new note
How to delete notes
  1. Tap Apps
  2. Tap Notes
  3. Tap the Edit icon
  4. Tap the Check box to select the note(s) you want to delete
  5. Tap Delete
  6. Tap Delete
