How to manage alarms on Mudita Kompakt
Updated 8 Nov 2026
Short answerTap the clock on the home screen to create and manage your alarms. The steps are below.
How to create an alarm
To create your first alarm:
  1. Tap the clock on the home screen*
  2. Tap Create an Alarm
  3. You can edit name and sound and the days it repeats
  4. Tap Create
To add additional alarms:
  2. Tap the Plus icon
  4. Tap Create
How to edit an alarm
  2. Tap on the time Alarm you want to edit
  3. Edit the time using the up and down arrows or using the keypad
  4. You can edit name and sound and the days it repeats
  5. Tap Save
How to delete an alarm
  2. Tap the Pencil icon
  3. Tap the Delete icon
How to snooze an alarm
Snooze is fixed to a 5 minute interval and is not automatic.
To snooze the alarm:
  1. Wait until your alarm rings
  2. Tap Snooze
*You can also unhide the app icon to enable access by tapping Apps > Alarm
