  3. How To Use Mudita Kompakt
How To Manage Mobile Data and Roaming
How To Allow or Stop Downloads Using Data
If you stop Kompakt from using mobile data, downloads will need a Wi-Fi connection.
This is useful if you have a limited data allowance or high cost for data.
  1. Press the Control Center button
  2. Tap Settings icon
  3. Tap Network and Internet
  4. Tap Mobile Network
  5. Tap the Mobile data Toggle switch to stop or allow Kompakt using mobile data
How to allow or stop roaming
Roaming is when you use your device outside of your home country.
Your network provider can charge you extra for this feature.
Always check with your network provider before allowing roaming!
To allow roaming:
  5. Tap the Roaming Toggle switch to stop or allow roaming
