  3. Kompakt Setup
How To Do System Updates on Mudita Kompakt
How to update MuditaOS K on Kompakt
When an update is available for Kompakt, you will see a notification at the top of the Control Center screen. You can also manually check for updates.
  1. Tap New MuditaOS K update is available
  2. Tap Update
  3. If needed: read, Tap the Check box and tap Agree to the licence agreement
  4. The update will download and configure automatically
  5. Tap Restart phone
How to manually check for MuditaOS K updates on Kompakt
  1. Make sure Kompakt is connected to the internet
  2. Touch the Control Center button
  3. Tap the Settings icon
  4. Tap About
  5. Tap Software Update
  6. If an update is available, you can update MuditaOS K
An OS (Operating System) update fails on Kompakt
There are a few things you can try if an update fails, a factory reset should be the last resort!
  1. Try the update again
  2. Check you have a stable internet connection
  3. If you don't have Wi-Fi, check that you allow downloads using data
  4. Restart the the device
  5. Do a factory reset
  6. If none of the above fix the problem, contact customer support
