  3. Features Overview
What is the Bedtime Feature on the Mudita Harmony and Mudita Harmony 2?
The Bedtime feature can serve as a reminder that your bedtime is approaching. This can be useful to know when you should start preparing for sleep.
How to Set a Bedtime Reminder
To access the Bedtime feature, enter your Harmony's menu by light-clicking the main button while on the home screen. Next, twist the main button to scroll down to select "Bedtime" and light-click it to open this feature.
Here you twist the main button to choose if you want the Bedtime reminder turned on or off. Light-click the main button to confirm your choice.
If you turn the Bedtime feature on, the next step is to choose what time you'd like it to activate.
  • Twist the main button to choose the hour and light-click to select it.
  • Twist the main button to choose the minute and light-click to select it.
That's it! When your Bedtime reminder is set and the chosen time comes, your Harmony will play a chime and display "It is your bedtime".
