  3. Features Overview
What is the Focus Timer Feature on the Mudita Harmony and Mudita Harmony 2?
The Harmony's Focus Timer is designed to help organize work and improve productivity.
This feature was introduced in version 2.7.0 of the Mudita Harmony's system. If you can't see the focus timer in your Harmony's menu, please update your alarm clock's software to gain access to this function.
How it Works
The Focus Timer lets you set specific time intervals during which you focus on your task, followed by a short break. The cycle then repeats. You can also set a longer break that activates after a specific number of focus and short break cycles.
How to Open the Focus Timer
To access the Focus Timer feature, enter your Harmony's menu by light-clicking the main button while on the home screen. Next, twist the main button to scroll down to select "Focus timer" and light-click it to open this feature.
Once you enter the Focus Timer menu, click on "Focus now" to begin your focus time or on "Settings" to set the Focus Timer according to your preferences.
Focus timer settings explained:
  • Focus time:
    Determines how long each focus phase will lasts. Can be set for 5 to 120 minutes, in 5-minute increments.
  • Focus timer repeats:
    Set how many focus timer cycles you'd like to complete. Can be set to between 1 and 19 times.
  • Short break:
    Choose how long you'd like your short breaks to be after completing a focus time phase. Can be set to between 1 and 15 minutes, in 1-minute increments. Can also be turned off.
  • Long break:
    Choose how long you'd like your long breaks to be after completing a specific number of focus time phases. Can be set to between 1 and 30 minutes, in 1-minute increments. Can also be turned off.
  • Long break after:
    Set how many focus time phases you'd like to complete before each long break. Can be set to between 1 and 18 focus times (depends on how many focus time repeats have been set).
