Does the Bell Use Bluetooth/WiFi? EMF Emissions?
Print
Modified on: Tue, 7 Mar, 2023 at 5:35 PM
The Mudita Bell does not feature any wireless technology and is suitable for EMF-sensitive users.
Self-Sufficient Device
The Bell has a simple design that does not require the clock to communicate with any other devices. As such, it doesn't feature Bluetooth, WiFi, or any other form of wireless communication. The only time the clock is connected to anything is when it's plugged into a charger.
All electronic devices naturally emit weak electric fields and Bell is no exception to this, but this field is so small that it's negligible.
Did you find it helpful?
Yes
No
Send feedback Sorry we couldn't be helpful. Help us improve this article with your feedback.
