Short answerMudita Dhamma Automatic is a Swiss automatic watch with a Sellita SW300-1 Elaboré movement, a 39 mm titanium case and 5 ATM water resistance, released in a limited edition of 108 pieces.
You will find a general description of the watch in the article What is the Dhamma Automatic?.
| Movement | Swiss automatic Sellita SW300-1 Elaboré, 25 jewels, 28,800 A/h (4 Hz) |
| Power reserve | Up to 56 hours |
| Accuracy | 5 ±5 seconds per day |
| Case | Titanium (grade 2), diameter 39 mm, thickness 8.35 mm |
| Weight | 35 g (without strap), 45 g with strap |
| Crystal | Sapphire, with anti-reflective coating |
| Water resistance | 5 ATM (50 m) |
| Dial | 12-hour, Arabic numerals, Dhamma Wheel as the seconds hand |
| Case back | Engraving “Buddha Dhamma Sangha” and the piece number (e.g. 001/108) |
| Strap | Vegan (Makro Eco), dark brown, 20 mm wide, quick release, titanium buckle |
| Edition | 108 numbered pieces |
| Origin | Designed in Poland, made in Switzerland (Swiss Made) |
