How to adjust the audio balance
Short answerGo to Settings, Accessibility and move the Audio balance control towards left or right.
Go to Settings, Accessibility and move the Audio balance control towards the left or right.
Change the balance
  2. Tap the Settings icon
  3. Tap Accessibility
  4. Find Audio balance in the audio section
  5. Move the Audio balance control towards left or right until it sounds right to you
When it helps
Balance is useful if you hear better with one ear. You notice it most with headphones. To have the same sound in both ears, use Mono audio instead, or together with balance.
