How to toggle ring or touch vibration
Short answerGo to Settings, Accessibility, Vibration and Haptic and use the Ring vibration or Touch vibration toggle.
Go to Settings, Accessibility, Vibration and Haptic and use the Ring vibration or Touch vibration toggle. From MuditaOS K 1.6, the same screen also has Notification vibration.
Turn vibration on or off
  2. Tap the Settings icon
  3. Tap Accessibility
  4. Tap Vibration and Haptic
  5. Tap the Ring vibration Toggle switch to feel a vibration when the phone rings or gets messages
  6. Tap the Touch vibration Toggle switch to feel feedback when you long press or use the Back, Home and Control Center buttons
Other vibration settings
  • From MuditaOS K 1.6.0 there is also a Notification vibration toggle in the same section. It turns off vibration for text messages, calendar and third-party alerts in one go.
  • Vibration can also be changed under Settings, Sound.
  • Each alarm has its own vibration setting in the Alarm app.
  • Touch vibration may not apply in every app.
