Short answerGo to Settings, Accessibility and turn Power button ends calls on or off. When it is on, pressing the power button during a call hangs up.
Turn it on or off
- Press the Control Center button
- Tap the Settings icon
- Tap Accessibility
- Tap the Power button ends calls Toggle switch
Before you turn it on
With this setting on, any press of the power button during a call ends it. That includes pressing it to wake the screen, for example to reach the dial pad in a phone menu. If you often need the keypad during calls, leave it off and hang up with the end call button on the screen.
During a call the screen turns off when you hold Kompakt to your ear and should wake again when you move it away.
