  3. System
How to Put Kompakt in Silent Mode?
There are two main ways to enable silent mode on Kompakt
Method 1: Using the Control Panel
  1. Open Control Center.
  2. Tap the Bell icon or slide the volume bar all the way down to mute the device.
Method 2: Using Settings
  1. Open Settings.
  2. Go to Sound.
  3. Turn on Silent Mode.
