  3. How To Use Mudita Kompakt
How To Add and Delete Fingerprints
How to add fingerprints
Kompakt’s power button contains a fingerprint scanner, letting you unlock you phone quickly without the passcode.
To add a new fingerprint:
  1. Press the Control Center button
  2. Tap Settings icon
  3. Tap Security
  4. Tap Manage Fingerprints
  5. Type your passcode and tap Enter on the keypad
  6. Tap the Plus icon
  7. Follow the onscreen instructions*
*Make sure you place a slightly different part of your finger on the sensor after each vibration
How to delete fingerprints
  3. Tap Security
  6. Tap the Bin icon next to the fingerprint you want to delete
  7. Tap Delete
