Harmony 2 technical specifications
Short answerHarmony 2 has a 2.84" E Ink display with a 2700 K front light, a 2600 mAh battery and a 3.5 W speaker. It has no Bluetooth or Wi-Fi.
Harmony 2 has a 2.84" E Ink display with a warm 2700 K front light, a 2600 mAh battery and a 3.5 W speaker. It has no Bluetooth or Wi-Fi: everything goes through the USB-C cable.
Specifications
ItemHarmony 2
Display2.84" E Ink, 600 x 480 px, 270 DPI, 16 levels of gray
Active display area56.4 x 45.12 mm
Front light2700 K, off by default
ProcessorArm Cortex-M7, 600 MHz
Memory4 GB
SpeakerMax 3.5 W TDA speaker
Alarm sounds17 built in, and you can add your own with Mudita Center
Battery2600 mAh lithium-ion, charging takes 3 to 5 hours
Battery lifeSeveral weeks of moderate use on the latest software
PortUSB-C, for charging, updates and file transfer
WirelessNone: no Bluetooth, no Wi-Fi
Weight230 g (plus or minus 5%)
Dimensions100 x 102 x 59 mm (width x height x depth)
MaterialABS
ColoursPebble Gray, Charcoal Black
LanguagesEnglish, Spanish, French, German, Polish
In the box and charging
Charge with a USB-C cable and a wall adapter. The adapter is not included. Charge for at least 3 hours before first use.
Harmony and Harmony 2
Both run the same system and get the same updates, so they have the same features. Harmony 2 has small hardware changes for stability. The battery capacity is the same.
