Battery: how often should I charge Harmony 2?
Updated 8 Nov 2026
Short answerThe Mudita Harmony and Mudita Harmony 2 each have a built-in rechargeable 2600mAh lithium-ion battery.
Charging is done through a USB-C port located on the back of the device.
How long can it last on one charge?
When updated to the latest system version, a Harmony or Harmony 2 should be able to last for several weeks of moderate use on each full charge. More intense use can reduce this time significantly.
The most energy-intensive parts of the Harmony are the speaker and the backlight. The brighter the backlight setting and the louder the volume, the more energy is required. Playing loud sounds for extended periods of time and frequent use of the backlight can cause the battery to drain quickly.
Compared to older versions of the Harmony's system, the clock's energy efficiency has improved substantially. A Harmony which still runs on outdated software may have significantly shorter battery life. The older the system version, the bigger this difference can be.
By keeping the clock updated, you can ensure that you get the most out of your Harmony's battery life, performance and functionality. We recommend checking for new updates regularly.
Useful links
