Ghost message sound with no notification
Short answerUpdate Kompakt first: older versions could play the tone for group messages they could not show. If it continues, the sound may come from an app you installed yourself.
Update Kompakt first. Before MuditaOS K 1.4.0, group messages were not fully supported, so the phone could play the message tone and show an unread badge for a message you could not open. After updating, owners found those old messages appeared and could be deleted.
1. Update MuditaOS K
  1. Make sure Kompakt is connected to the internet
  2. Press the Control Center button
  3. Tap the Settings icon
  4. Tap Software Update
  5. If an update is available, tap Update
MuditaOS K 1.4.0 added full group messaging, and 1.6.0 fixed duplicate notifications for texts that arrived after a group message.
2. Check apps you installed yourself
Kompakt has no notification tray. Apps you sideloaded, such as WhatsApp or Signal, can still play a sound, but nothing appears on screen. One owner found the sound was a WhatsApp status like, not a message. Open those apps to see what arrived, or turn off their notification sounds inside each app.
3. Other causes owners have found
  • A sound right after you turn the phone on can come from the SD card being detected.
  • Receiving a file over Bluetooth plays a system sound with nothing to tap.
  • Some owners fixed ghost sounds by removing numbers from their blocked list. This can let spam through again, so try it only if the steps above do not help.
Still happening?
Restart Kompakt. If the sound keeps coming with no message, contact customer support and tell us your MuditaOS K version and whether you use sideloaded apps.
