Kompakt safety info for spare parts and accessories
Short answerRead these warnings before fitting a Kompakt spare part or using a Kompakt case or screen protector. The battery has the most important ones.
Before you fit a Kompakt spare part, or use a Kompakt case or screen protector, read the safety warnings below. They come from Mudita's two safety documents, which you can download at the end.
For all parts and accessories
  • Use them only with compatible devices.
  • They are not toys. Keep them away from children.
  • Keep them away from extreme heat or cold, and do not go beyond Kompakt's recommended operating temperatures.
  • Some materials may cause allergic reactions. If your skin gets irritated, stop using the product and see a doctor.
  • Dispose of them under your local waste rules.
For spare parts also: read the installation guide first, make sure each part fits properly, and keep parts away from liquids and moisture.
Extra warnings by product
ProductWarning
BatteryRisk of short circuit if fitted wrongly, and of fire, explosion or burns if mishandled. Do not puncture, crush, take apart or modify it. Stop using it at once if it swells, leaks or overheats. Never burn it or put it in household waste.
Display moduleGlass can break and cut you. Risk of short circuit if fitted wrongly. Clean the outside with a mild detergent only.
Back coverClean the outside with a mild detergent only, no harsh chemicals.
SIM traySmall part, choking hazard.
Screen protectorTempered glass can crack under strong pressure or impact. Replace it if damaged to avoid cuts.
Protective caseNo extra warnings. Clean with mild detergent and water.
Report a product you think is unsafe
Email support@mudita.com and include:
  • Your full name and phone number
  • The product name and its EAN or serial number
  • Where and when you bought it
  • What went wrong
Every product has a unique EAN or serial number on its label for tracing. These products comply with EU Regulation 2023/988 on general product safety.
Download the documents
