I forgot my Kompakt PIN or screen pattern
Short answerIf you forget your PIN or screen pattern, you will need to perform a factory reset to regain access. This erases all data on the phone.
If you forget your PIN or screen pattern for the Mudita Kompakt, you will need to perform a factory reset to regain access.
This process will erase all data on the phone, so please be aware that any information not backed up will be lost.
Factory reset procedure
  1. Power off the phone
  2. Hold Power and + Volume Up buttons together until you see the "Select Boot Mode" screen
  3. Use the Volume Up button to scroll to "Recovery Mode", then click the Volume Down button to press "OK"
  4. Once the screen shows a broken robot icon, press and hold the Power button, then click the Volume Up button once to open the Recovery menu
  5. Use the Volume Up/Down buttons to scroll to "Wipe data/factory reset" and click the Power button to confirm
  6. Wait for the factory reset to complete
