Files do not show when connecting Kompakt via USB-C
Short answerIf you connect Kompakt to your computer but can’t see your files, you’ll need to allow file transfer.
To allow file transfer
  1. Connect Kompakt to a computer with a USB-C cable
  2. Press the Control Center button
  3. Tap the Settings icon
  4. Tap Connected Devices
  5. Tap USB Preferences*
  6. Tap File Transfer
*If Kompakt isn’t connected to the computer, you won’t see this option!
