  3. Origin, Specs & Components
Mudita Moment Technical Specifications
The Mudita Moment is a quality watch with an automatic movement. Its technical specifications are listed below.
Colors: Gray, white, or black
Mechanism: Miyota 9015
Power reserve: Up to 42 hours
Case diameter: 38mm
Case thickness: 10.8mm
Case material: 316L stainless steel
Type of glass: Sapphire glass
Water resistance: 5 ATM (50m)
Lugs bars: With a quick spring bar movement
Strap width: 20 mm, with a 316L steel buckle
Watch weight: 55.1g without the strap
What's included in the box?
  • Mudita Moment watch
  • Unisex vegan strap
  • Watch information (about the mechanism)
  • Strap information
  • Breathing exercises manual
  • Guarantee and documentation
