Short answerThe Mudita Moment Automatic uses an automatic movement. Its full technical details are listed below.
Colors: gray, white, or black
Mechanism: miyota 9015
Power reserve: up to 42 hours
Case diameter: 38mm
Case thickness: 10.8mm
Case material: 316L stainless steel
Type of glass: sapphire glass
Water resistance: 5 ATM (50m)
Lugs bars: with a quick spring bar movement
Strap width: 20 mm, with a 316L steel buckle
Watch weight: 55.1g without the strap
Winding a stopped watch
The Miyota 9015 can also be wound by hand. With the crown pushed in (its normal position), turn it clockwise 15 to 20 times. This fully winds the mainspring and starts a stopped watch.
What's included in the box?
- Mudita Moment Automatic watch
- Unisex vegan strap
- Watch information (about the mechanism)
- Strap information
- Breathing exercises manual
- Guarantee and documentation
