How to create a backup for Kompakt
Short answerIn Mudita Center, open Your Kompakt, then Overview, and click Create backup. You protect the backup with a password.
  2. Look under Your Kompakt > Click Overview
  3. Click Create backup
  4. Click Create backup to confirm
  5. Create a password to protect your backup data*
  6. Click Confirm passcode
  7. Enter your passcode to create the backup
*Warning! You can not change the password after you confirm it.
if you don’t want a password, click skip password to create the backup
