How to block hidden or unrecognized numbers
Short answerYou can block all incoming calls and messages from hidden numbers. You can also choose to block all numbers that you don’t recognize, you will only receive calls and messages from numbers in your contacts list.
To block all hidden or unrecognised numbers
  1. Tap Phone
  2. Tap Recents
  3. Tap App settings icon in the topbar
  4. Tap Call Blocking
  5. Use the Toggle switches to select either Block hidden numbers or Block unrecognised numbers
