Short answerConnect Kompakt to Mudita Center, open Contacts, then Manage Duplicates alongside All Contacts to merge them. You need Mudita Center 4.0.0 or newer and MuditaOS K 1.5.0 or newer.
Connect Kompakt to Mudita Center, open Contacts and use Manage Duplicates, alongside All Contacts under Contacts, to merge them. This needs Mudita Center 4.0.0 or newer on your computer and MuditaOS K 1.5.0 or newer on Kompakt.
Before you start
- Update Mudita Center and Kompakt to the versions above.
- Create a backup first, in case a merge does not turn out the way you expected: in Mudita Center, look under Your Kompakt, click Overview, then Create backup.
Merge duplicate contacts
- Open Mudita Center and connect your device
- Look under Your Kompakt and click Contacts
- Click Manage Duplicates alongside All Contacts under Contacts
- Review each suggested duplicate, then delete or merge it one at a time
- Check your contact list after merging
Do not disconnect Kompakt while Center is changing your contacts.
Why duplicates happen
Duplicates usually come from importing the same contacts twice, for example from Google and then again from a vCard file. If you plan to import again, delete the old copies first: select them in Contacts with the Checkbox and click Delete.
